Corinium Table Top Press - Suffolk, UK
Started by Dave Hughes, March 05, 2025, 07:15:05 AM
Corinium Table Top Press built in 2019 by Beyond Letterpress Ltd.*
The Corinium is the smaller one of two high quality desktop printing presses designed and manufactured by Beyond Letterpress Ltd at their Cotswold workshop. Bought new in 2019 for approximately £2.000
Adjustable impression makes them easy to use with all types of etching or letterpress printing blocks and type.
Designed to use anywhere for the hobbyist or serious printer and artist.
Maximum paper sheet size 400mm x 590mm.
Print area is 320mm x 450mm (A3 plus).
The printing bed is 20mm thick milled and ground steel.
The impression roller is solid steel coated with hard rubber compound.
Adjustable roller height approximately minimum 20mm - maximum 42mm.
Weight approximately 65kg (Needs two people to move).
To see the press in use go to: https://www.beyondletterpress.com/tabletoppresses.html
Chase and furniture included.
Collection preferred but might be able to deliver to a reasonable distance from Ipswich area but would need help to unload.
