11pt Baskerville Monotype Matrices - Sussex, UK
Started by Dave Hughes, May 26, 2025, 08:47:47 AM
Rare Monotype Matrix Case – 11pt Baskerville Outside (Scheme 4A) – Letterpress P*
rare and original Monotype matrix case featuring the classic Baskerville typeface in 11pt size.
This is the Outside case, traditionally used in conjunction with the Monotype Composition Caster, and follows the Scheme 4A layout. The case is labelled clearly as "Baskerville Outside 11", and appears to be in very good condition.
These matrix cases are increasingly difficult to find complete, especially with such a widely loved serif typeface and at this size. Ideal for letterpress printers, type collectors, or typographic history enthusiasts.
Details:
  • Typeface: Baskerville
  • Size: 11 point
  • Case Type: Outside case (Scheme 4A layout)
  • Original Monotype hardware
  • Clean, dry storage
  • Vintage hot-metal typesetting equipment
Please see the photos for detailed views of the matrix layout and label.
Compare the matrix case with the reference scheme (Scheme 4A, Baskerville Outside 11pt) visible in the included layout
 chart. The case is largely full and matches the intended character arrangement — see top-down photo for details.
Dimensions:
24cm x 9cm x 3.2cm
[/i]
David Bolton
Baskerville yes, but looking at the actual box contents the mats are not all 11pt, and not complete founts, but just a few outside sorts (AE OE etc) in a range of sizes. Even then, the mats are not quite as indicated in the sheet stuck to the lid - eg the ? are missing. So not much use to any printer, apart from the few that have Monotype casters, who probably already have enough Baskerville.
And indeed the sale seems to have re-appeared at a lower price, but still very optimistic.
David Bolton
