How to use the Forum - A Quick Guide to the Features
Started by Dave Hughes, May 16, 2022, 09:44:26 PM
Making a Post
Making a post on the Forum is fairly straightforward, but here are a few features you may not be aware of.
Here is the posting screen:
If you wish to post a Youtube video, Tweet (X) or Instagram post the Forum should be able to do the work for you. Just paste the URL of the item on a line of its own, and the software should render it properly.
This button on the toolbar toggles between code view and wysiwyg view. This can be useful if you are doing a lot of formatting in your post.
If you are working on a large post, it is possible to save a draft, just press the "save draft" button under the message box, instead of the "post" button, it will be stored for a month, and can be retrieved from this menu:
If you want to post a photo you have two/three options. If the image is already hosted somewhere on the internet you can press this button on the toolbar and enter its URL.
Small images can be added by pressing the large  "Click or drag files here to attach them" button underneath the message box. You will see this:
Don't forget to click the blue "upload" arrow on the top right of the image to complete the process.
If the image is larger and not hosted anywhere you can click the "Add image to post" link at the bottom left of the text box, follow the instructions and the image will be uploaded to a hosting service and put into your post.
If you wish another member of the Forum to be notified of your post, you can mention them by posting their username with an @ sign in front, and they will be alerted about the mention.
Browsing the Forum
When browsing the forum the bottom of each post has a couple of buttons you may need to use.
The thumbs-up "like" button on the left hand side needs no explanation. Like what you see? Then click the button to let the author know.
The green heart button further to the right allows you to bookmark the post, adding it to your personal collection of bookmarks, which will then be accessible from the menu pictured above, where your draft posts also appear.
If you have any further questions please send me a private message. You can do that by pressing the button under my name on the left side of this post. You can also contact any other member by doing the same.
Each Board has its own RSS feed, which can be accessed with the image next to the Board Title.
Register to Unlock all Features
Please note, some of the features mentioned above are only available to registered members of the Forum. Guests are allowed to post, etc. but to access the full set of features you should Register for a free account.
