Nozzle Alignment Gauge
Started by Terrence Chouinard, December 18, 2024, 10:24:38 PM
Terrence Chouinard
Hi all, Can any of you out there tell me if the nozzle alignment gauge is any different than the base of a stripped down composition mould?
I seem to have left mine in my other pants. I'd appreciate any & all information.
Thank you.- Terrence
Minty1310
Hi
The alignment gauge is a flat cast plate with I think two positions for nozzle alignment.
It is about 3/8" thick and is far better to use than a dismantled  mould as you can see the approach of the nozzle as it rises into position to make sure it engages correctly.
E.B.🇬🇧
Retired Compositor and Monotype Caster/Supercaster operator. Monotype trained  for maintenance and service.
Minty1310
These are the parts you need to align and Centre your nozzles.
E.B.🇬🇧
Terrence Chouinard
Many thanks. I have a squaring post and I'm happy to report all was right (angle) in the world. Without a proper cantering plate I improvised with a mould base in hopes it would diagnose whether or not I've an issue with the nozzle seating correctly. It appears I do from the likes of this footage. you can see the nozzle approach from the side as I'm only raising and lowering the pot. Thoughts?
https://www.dropbox.com/scl/fi/ztk7cx1jbgllo84cyh0w1/IMG_3025.mov?rlkey=8a2alrdbrtbpznz3mm9vnchjo&st=2v8rl78r&dl=0
