Mexican Monotype Meddling?
Started by Dave Hughes, March 05, 2013, 09:10:41 PM
Video of a Monotype being operated in Mexico.
Not sure what these guys are doing. It looks like they are just casting a few "sorts."
I've never used a Monotype but it looked like they weren't using the standard matrix block.
Also, near the end where they were squirting the metal up, looked a little unprofessional!
Monotype Machine - Hot Metal Typesetting
John B Easson
Great stuff.
I'd have loved to have had a translation - looked like an explanation going on. The matrix looked like a US Lanston display one to me, in the special holder used for casting on the Composition Caster one character at a time. The metal squirting at the end is perfectly normal to check the nozzle is clear, and I think was just to show the nozzle and molten metal in this case! I was intrigued by the stripped-down look of the machine - mine (a UK one) has lots on the top hiding the wedges he demonstrates at one point, and over the controls as well: maybe the machine was only used for casting this way, not for normal composition work.
Eric Brown
Far from messing around these guys were demonstrating a Monotype Sorts caster, I have not seen one quite like this as it looks like a cross between a composition caster with the complicated gearing system of a Super caster. It has no air tower for taking the spool paper of a composition caster, but unlike a super caster it looks like it will not cast leads and rules as it has no cutting mechanism.
I stand corrected.
As I mentioned in my original post, I have never really had much experience with the Monotype system.
I just thought the video looked interesting - as it has proved to be.
This Monotype section was recently introduced to Metal Type, following a request from a site user.
I'm glad it's proving to be interesting.
These people are operating a type&rule caster, with the holder for american matrices, than the tongs are not needed, and those can be taken away.
the diecase is put in a fixed position, all type are made in this single position. (G or H 8)
like a super-caster only single characters are cast.
the correction wedges cannot be adjusted on the normal way, but are placed in the right position manually.
There's a lot more missing on this machine.
besides the papertower...
missing on this machine:
- the springbox and its cam
- the locking bar cam lever and the mechaniism to lock the bars
- all the pins are missing,
- the galley-mechanism at the front
- the tray above the galley-mechanism
- the matrix-case is always in a fixed position
therefor this machine is only to be used sorts, using american super caster mats,
and it cannot be used for texts.
What is more - the caster looks like it has always been like that. I'd say it was built as a type&rule caster, and not a composition caster.
After studying some plates in the English spare parts book, it occurs that they also made a simpler non-composing machine based on the composition caster, but vastly simplified.
The justification pin block is not there (instead, a solid piece of metal without holes in it), some of the unneeded cam levers are not installed (most notably: for the tongs springbox).
The diecase is actually not in fixed position, it can be moved by means of hand-operated draw rods instead of the tongs mechanism.
Here:
https://www.youtube.com/watch?v=hQf4dSMei3o and
https://www.youtube.com/watch?v=FVlqbK9df4Y you can see a simmilar machine and its matrix case positioning system. Rather than being "stripped down" - it was not "built up" in the first place.
