Linotype Model 25
Linotype model 25
THE ADVANTAGES of multiple distribution are not confined to work on which it is desired to mix matrices from various magazines.
Multiple distribution means that any character in the machine is available at once; that you can shift from one magazine to the other or set a correction line from either, without even waiting for the last line to distribute.
Change of operative position on magazines is made instantly by a single movement of a conveniently located lever, without interrupting distribution. Magazines can be shifted while matrices are in process of distribution.
As on all Linotypes, any magazine can be removed from the front of the machine and change in only a few seconds.
Two main magazines. Built for either 30 or 42 picas maximum measure.
Linotype fan? Don’t miss the Linotype Chat section of the Metal Type Forum.
